Hello VAF!
Easy question (hopefully). I need to replace the fuel tank drain because it won’t quit dripping. Any ideas on which one I need to buy off Aircraft Spruce?
Thank you for your time!
Matt
You may also just find a piece of debris lodged in there. I had to pull mine a few times when the plane was new.
Larry
Does this get better with time? I must have pulled and cleaned each drain 3 or 4 times! Always some tiny piece of debris, 40 hours or so on the airplane.
