Fuel Tank Calibration Issue
n74846
I recently installed a manufactured tank to replace the original. The Dynon SkyView showed exactly the reverse of the Moeller gage and the voltages under Calibration are reversed. I did a re-Calibration and the issue resolved. The voltages are now exactly reversed and the SkyView display is correct. As there is only one wire attached, what would cause this effect?
Interestingly my volts are very close to your numbers now ( /100), which may mean the builder installed the sender upside down. Thanks for the info.
what kind of tank?
