Do I need to install the fuel fittings on the inboard fuel tank with proseal? What I mean by that is can I install everything dry and then coat the inside and outside with proseal or should I apply sealant to the shoulder of the fitting as I install it into the rib and torque it down? Then come back and encase both sides in sealant.
