WingedFrog
While building the fuel tank, my attention was focused by the warning on page 37-03 about the fuel passages between the main compartment and the area where the fuel lines connect. These passages are clearly intended to allow the rest of the fuel in the main compartment to feed the fuel lines once the level of the fuel in the tank is below the top of the baffles. As the passages are very tiny, a friend of mine deemed it unlikely that they would be able to produce a fuel flow of up to 5 Gal./hour. Concerned, I called VANs and was told that the role of the baffles is to prevent the fuel to go in the back of the tank during the nose up of a go around with low fuel. This makes perfect sense to me, but... how will I ever get in this situation if the engine dies as soon as the level of fuel gets under the level of the baffles?![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
