DRBuilder
For Mitch Locke... Why are 1100-08 plate nuts (countersunk) used here instead of 1000-08 plate nuts? The spar flange is countersunk to accommodate the dimpled fuel tank skin with 8-32 flat head screws. The 1100-08 plate nut creates a void between the flange and the plate nut threads.... not good. Not to mention, the 3-3.5 rivets are too short to create a good head on the 1100-08 due to the thickness of the plate nut. I installed the 1000-08 plate nuts in 2 of the locations and they work perfect, with no void between the spar flange and the plate nut threads. Can you comment?
Links to pictures below.... (I tried to post them in the thread but they are HUGE and you need to use the toggle bar to slide back and forth to see the entire photos)
http://www.drrv7.com/files/IMG_0004.JPG
http://www.drrv7.com/files/IMG_0005.JPG
