From the factory FB page.
"We've had several RVator articles over the years about the perils of modifying the fuel system, but it may be time to revisit the subject.
We were recently contacted by the NTSB with regard to a fuselage fire in an RV-10 with an automotive engine installed. This had what was described as a 'standard RV-10 fuel system', but the picture below forwarded by the NTSB showed plumbing which left our technical staff's jaws hanging slack in disbelief. We counted 28 clamps on the rubber hoses, but may have missed some.
Obviously, we strongly discourage any deviation from the plans, but if a builder decides that changes must be made, it is best to use approved aviation practices for fuel systems as outlined in AC43.13. The AN fittings and aluminum line shown in typical RV plans are based on current certified airplane standards and are reliable. The arrangement as shown is potentially lethal, more so if used in high pressure systems (Lycoming fuel injection systems typically run around 25psi, some automotive types may be 60psi or higher!). The cause of the presumed fuel leak/fire in this case is not known, and we await the NTSB's verdict with interest, but irrespective of their conclusion, a fuel system like this is simply a Bad Idea.
Whilst we have great freedom to experiment with RVs, the fuel system is one area where proven aerospace techniques and materials are always the best course."
![189366_137339519670321_121827541221519_220142_2823898_n.jpg](/proxy.php?image=http%3A%2F%2Fa3.sphotos.ak.fbcdn.net%2Fhphotos-ak-snc6%2F189366_137339519670321_121827541221519_220142_2823898_n.jpg&hash=9b4dc70441cc48cf7afc6632803ae82d)
