Revised Plans
OK, now I get it. My QB fuselage was built according to the old plans. My newer plans show the valve in a lower position with an extension, the bracket upside down and backwards from the old plans, and a 90 degree fitting where the fuel line enters the tunnel. The old plans show no fitting, a big rubber grommet where the line enters the tunnel, and the fuel lines anchored to the tunnel walls with cushion clamps.
I am going to rivet an aluminum patch over that big hole, and drill a new hole sized to the fitting so that I can install according to the newer revised plans. This cost me an afternoon of work, but I really like the valve in the lower position considering the improved routing of rear seat heat duct (Section 50).
