I am a few weeks away from beginning the build up of the plumbing portion of my fuel system. I have been running through past posts and build logs trying to learn as much as I can and found lots of interesting data and ideas but a lot of the relevant posts I see are several years old. Looking for more recent data. I plan on running an injected motor and I am looking at a setup that does not have a return line to avoid the weight and complexity.
Tell me about how you set up your aircraft. What/whose parts did you use?
What did you like or dislike about them? Would you do it again?
I saw some people putting filters in the wing root. On the one hand it seems a good idea since you would not be spilling fuel on the cockpit floor during servicing. On the other hand, that seems like an awfully cramped area to be working. Thoughts?
