Fuel Servo to Fuel Flow Divider
timandmeli
Hi All,
I'm plumbing my engine and am not sure on which Vans pre-made fuel line to use from the Fuel Servo to the fuel flow divider. I have a Horizontal IO-360 with the silverhawk fuel servo. There is a hole drilled in the intercylinder baffle between #1 and #3 cylinder. Does anyone recall which hose is the correct length from Vans, They have three listed in the accessory catalog. Thanks in advance. Tim
