Do you have to remove the large inspection plate or can you just remove the fuel sender plate
Use steal brush on cordless drill to remove all proseal from exterior edge, get the screws out.
Take 2-3 inch putty knife and sharpen the edge. Hit with hammer at as low as an angle you can , in the space allotted. Once under the edge, it comes off.
This is what I did
