There was some discussion here on VAF about this topic a good while back that prompted me to install a 2" length of wire with a ring terminal on one end that gets "gently" tighten to the fuel sender terminal screw; the other end has a Faston 1/4" terminal. That way, the sender can be disconnected if need be without disturbing the fuel sender terminal.
