Recently I reinstalled my fuel tank after fixing a fuel flow problem and installing a Moeller fuel gauge. But I found that the Dynon reads the tank as empty. In the VAF archives I found very clear instructions for testing the sender with an ohmmeter. It showed the sender was faulty ? infinite resistance between the screw and the flange, instead of 30 to 200 ohms
I had noted when I tightened the screw on the centre of the sender, that the sender centre turned with the screw with a modest tightening. I left it at that, after doing a few revolutions of the screw plus fitting.
I can?t remember the setup behind that screw and flange, but I fear some wire has been twisted past breaking point. Or could it be a displaced wiper (something else I read in a VAF message)?
So I need answers to a few questions please.
? If the centre piece rotates, could it break the conductors? Perhaps someone could look at an uninstalled sender for me.
? Can the wiper be dislodged?
? Can I simply unscrew the flange, pull out the sender and check it? I?m so tempted.
? Is the sender likely to be repairable? Or should I just order a new one now?
? I don?t think I used unreasonable force to tighten the connector screw. Has anyone else had this problem and made a warranty claim?
Rod
Rod
