JackinMichigan
I have a late 2012 RV-10 kit.
I have installed the stock Van's fuel selector valve.
I really like the fancy indicator plate and red selector pointer and I called Van's and they said it would work with the stock valve.
It doesn't, and I can't figure out how to make it fit with out extensive modifications. My stock configuration has a spring loaded pointer that has to be lifted to turn, with a positive stop with a pin that goes into a hole in a small plate for all 4 positions. (which I like by the way)
I called Vans tech support and the guy said he is unfamiliar with that stock Vans valve selector. The design must have changed.
Has anybody else encountered this. The Vans tech guy said just send it back and make your own fancy indicator plate, which I plan on doing if somebody else doesn't have a simpler answer....
