Has anyone found a fuel sampler/tester what works well with the RV-12
J jsenft Well Known Member Feb 3, 2015 #1 Has anyone found a fuel sampler/tester what works well with the RV-12
Bill_H Well Known Member Patron Feb 3, 2015 #2 The test-tube type works fine. You can see it through the exhaust pipe hole as you insert it into the access hole below the gascolator.
R RFSchaller Well Known Member Feb 3, 2015 #3 I use what Bill described. I always rinse it with isopropyl alcohol after use to eliminate the auto gas smell. After 3 years my cockpit still has the "new car" smell as opposed to gasoline smell.
