jcaplins
I need to drill the 1" holes for the fuel line + grommet that will pass through the F-770 side skin and gear attachment plate. The plans only call for a 1" hole on each side of the fuselage. My engine is fuel injected and so I need a return line to the tanks. What have others done in this situation? just drill a 2nd 1" hole below the first? Is there a better option or place for the second hole?
I will have a return line for each tank. left tank has flop tube, right has regular fuel pickup tube. I do not have any fittings installed or located in the fuel tanks for the return lines yet.
