Anyone used a Weldon D8100-F Aux fuel pump on a RV7? This pump is firewall mounted. Thanks
P pilot28906 Well Known Member May 1, 2015 #1 Anyone used a Weldon D8100-F Aux fuel pump on a RV7? This pump is firewall mounted. Thanks
Walt Well Known Member May 2, 2015 #2 I've been using one for many years, oeration has been flawless. I mounted inside on the RH side under the CP rudder pedals. You can see it in the pic below.
P pilot28906 Well Known Member May 2, 2015 #3 Thanks Walt. Do you have a filter before the pump? If so, what type?
Walt Well Known Member May 2, 2015 #4 Yes I use a 74 micron Flowezy filter right after the selector valve. http://flowezyfilters.freestarter.com/
