cardinalflier
My Weldon fuel pump occasionally trips my new 5 amp circuit breaker when turning on the fuel pump for my first start of the day on my IO360. Thoughts? Is 5 amp enough for thr Weldon pump? Is my pump starting to fail? The c/b won't trip again during the day, unless my battery voltage drops. I solved my battery voltage problem by replacing the 40 amp alt with a PP 60 amp. This is all after i completed a panel upgrade with a complete Dynon Skyview install in my RV6. TIA for the help. Bruce
