647jc
Regarding the Vans / Aircraft Spruce Primer Valve 05-29823. Is there a proper flow direction? I read a post somewhere that said there was (they actually called the Parker Co.) to find out but now I cannot find that post again or any information regarding the flow direction. My valve has two ports marked 1 and 2 but no flow direction indicated anywhere. Looking inside the ports, they are somewhat differen't so I imagine there is a correct flow direction although it will probably work either way.
JC
JC
