Has anyone installed the Dynon Kavlico fuel pressure sensor with D180? Can you share experience?
4 431HG I'm New Here May 21, 2012 #1 Has anyone installed the Dynon Kavlico fuel pressure sensor with D180? Can you share experience?
P Peterk Well Known Member May 22, 2012 #2 431HG said: Has anyone installed the Dynon Kavlico fuel pressure sensor with D180? Can you share experience? Click to expand... Yes and it works great...steady as a rock...AFTER you install a uf330 capacitor to dampen the erratic behavior. Much better device than the VDO.
D Dave12 Well Known Member May 22, 2012 #3 You must have the latest upgrade loaded to support the Kavlico and you will have to supply voltage to it. It is easiest to tap the voltage going to the map sensor. It appears to be of decent quality.
