This is an improvement to the D180 fuel pressure sensor connections.
SkyViewers need read no further since the new avionics comes with a different and, hopefully, improved sensor.
I had been having jumpy fuel pressure readings that I traced to the slip on spade connectors on the sensor. The readings would appear normal then would jump into the yellow or red zone, sometimes to full scale red. Naturally, the alarm would sound just as you would be trying to talk on the radio
. This type of behavior did not seem to be a component failure but more likely a high resistance connection to which the Dynon is sensitive. When you pull off one connector, i.e. high resistance, the Dynon pegs to the red. When doing the troubleshooting I examined the fuel pump and could find no indication of failure there.
In looking at the sensor, it actually has nutted terminals to which the spade tabs are attached. Why not just remove the tabs and connect the wires to the sensor with ring terminals?? So... that's what I did.
I have flown the aircraft for several hours since and fuel pressure readings are very steady.
There have been many posts about jumpy fuel pressure readings on the forum, this easy fix might solve a lot of that. It will at least remove possible high resistance connections in this circuit.
Tony
![i-XfDz7K2-L.jpg](/proxy.php?image=http%3A%2F%2Ftonytessitore.smugmug.com%2Fphotos%2Fi-XfDz7K2%2F0%2FL%2Fi-XfDz7K2-L.jpg&hash=8fda87ac510a1aa92edb9ca49fb4cbfa)
Tony
