Yes! I used the version with an NPT male thread on one end and screwed it into the output port of the flow sensor (red cube), which is down stream of engine driven pump. I also installed an AN816 in the female NPT with a flexi-hose to a manifold for the fuel pressure sender. But can't see any reason not to install sender directly into this fitting. I put a P-clip around fuel hose so any vibration is not stressing this fitting.
Pete
