Lionclaw
My engine (320-h2ad) has a forward mounted fuel pump. I'm planning on routing the fuel line from the gascolator up over the top of the engine to the pump, then back to the firewall, down the back, and then under to the carb.
This leaves me wondering where to hook up a fuel pressure line. I think the baffles are too close to the pump for the tee'd fitting to work on the pump. Should I put a tee on the carb, or would it be an acceptable practice to put a tee mid-line behind the engine on the run between the carb and mech fuel pump?
Does the pressure line get a restrictor of any sort? Firesleeve?
Thanks!
Thanks!
