WingnutWick
Hello all,
I need to replace my RV-10's VDO fuel pressure sender. It is using a VDO 0-5bar sender but when I look up on Spruce for this sender the only one I find says "oil pressure sender" and it says in the notes:
VDO pressure senders are not to be used with any type of fuel application.
VDO pressure senders are not suitable for use in aircraft.
https://www.aircraftspruce.com/catalog/inpages/vdooilpressuresender.php?clickkey=24047
Is this just legal notes and is using this pressure sender for fuel PSI common practice?
Charles
Charles
