Fuel Lube on Brake Fittings?
pmccoy
Van's calls for fuel lube on all the AN fittings in the fuel system. Should I use that on the AN fittings with the brakes as well?
that leaks
Someone at Vans said to use the fuel lube, but the high pressure areas leak, not bad but not good. I then used the teflon paste. I had to clean the threads well.
Question
I am just about to fabricate the fuel and brake lines on my RV project. I see the term "fuel lube" used here and in other threads. Is this a generic term? ACS sells EZ Turn with the words "fuel lube" in parenthesis. Is this the actual product you are all using? I?m trying to learn about this new phase of my project.
Sincerely,
Sincerely,
Yep, that's the stuff!
