Having some trouble laying out a fuel line from the mechanical fuel pump to the FI throttle body. Engine, Aerosport IO-320 vertical induction with Silverhawk FI. Port (left) side has mixture arm pointing up. Right side has Throttle arm pointing down. the inlet for the injector is on the right with a straight-6 flared tube fitting. Vetterman crossover exhaust.
Consideration is for fuel line on port (left) side but has to traverse under the twin exhaust tubes and then under oil sump and wind between engine mount.
Less prolematic is the fuel line going up the right side of the engine but this would not clear the throttle arm unless the inlet fitting extended 3 more inches out to the side.
Looked up and down and cannot find a solution on VAF. Perhaps I should have made the air filter box with the mixture arm down, but this route is not that good for reducing heat to the fuel line. To bad the injector body does not have a inlet on the right rear.
Has anyone flown a solution to this question. I do have pictures but do not know how to post at this time.
