LettersFromFlyoverCountry
Apparently, there is a missing step in the RV-12iS instructions. You have to countersink or enlarge the holes on the three plastic "holders" for the fuel lines through the main channel. Otherwise you get this.
Pulling those lines out to be able to get the plastic doohickeys off the large "studs" is going to make my day. But that's the way it goes.
Even if I do that, however, that looks like a REAAAALLLLLLY small clearance between the filter bypass line and the flaperon mixture arm.
Is there anything else I'm missing here?
![37296236_10156640126984216_4475167944598355968_o.jpg](/proxy.php?image=https%3A%2F%2F3.bp.blogspot.com%2F-qAmAoLhOmCs%2FW09-l8InEwI%2FAAAAAAAAq3s%2F2v0m08fgwp0eu3k2INGIpFrFmgzZ20BvwCLcBGAs%2Fs640%2F37296236_10156640126984216_4475167944598355968_o.jpg&hash=ad9a290fdbbec592a1c230e21ffd6576)
