drone_pilot
Here is hopefully an easy question.
What is a good product for sealing the AN fittings on my fuel and vent lines?
Tite Seal is much better.. fuel lube must be good for something, I'm just not sure what that is
http://www.aircraftspruce.com/catalog/eppages/titesealit.php?clickkey=23262
Reading in between the line here... You must have some negative experience with ez turn to speak of? And I'm not talking inadvertent application to the flared portion of a fitting.
Tite Seal is much better.. http://www.aircraftspruce.com/catalog/eppages/titesealit.php?clickkey=23262
Walt.....thought I'd pick up some of the Tite Seal since I'm going to re-do all my fuel lines on my 6A, but noticed there is a "Light Weight" and a "Medium Weight". However; there is no description on the difference. Which would you recommend?
I have used fuel lube/ EZTurn as a thread lubricant in fuel/oil lines but not as a sealant.
Tite Seal is much better.. fuel lube must be good for something, I'm just not sure what that is![]()
/QUOTE]
I use fuel lube as a gasket dressing and have great luck with it for that. But some put their gaskets on dry and have success so what do I know. As others mentioned, it works great to hold together washers and nut stacks in hard to reach places when I run out of boogers.![]()
Ben, here's a description on how to tighten flare fittings:
http://www.new-line.com/blog/how-to-tighten-jic-fittings
What is a "thread lubricant" if not used for sealing?
