Selector plumbing
Don?t know if it helps, but, the engine on my 4 is out of a twin Comanche, I simply copied what Piper used for their fuel system. My electric pump was from the Comanche, so it has an internal bypass and is in the tunnel just forward of the fuel selector. The system you buy from Van?s has a pressure bypass external. The fuel flow transducer is on the fire wall past the gascolator just prior to the mechanical fuel pump. If I were to put an in-line filter in, I would install it just after the boost pump and before it goes through the firewall. The battery is in the baggage compartment, so there is room in the center tunnel. The engine is an IO320-B1A, beem flying sence 1993.
Hope this helps
Randy
