This post relates to my RV-7A with IO-360, vertical induction and Air Flow Performance fuel injection. I am perplexed trying to figure out how to run a fuel line from the fuel control servo to the flow divider. The fitting on the fuel servo is on the aft side. The flow divider is on top between the #1 and #3 cylinders. I know there is a hole in the lower cylinder baffle for this line to pass but the question is how to get it there from the servo. There are two basic directions one can go (around the left side and around the right side of the sump) and there are many obstacles in the path between the servo and the flow divider. I also have the EI FT-60 "red cube" fuel flow sensor that I have been told should be located somewhere between the servo and the flow divider.
Can anyone give me some guidance how to route this line and where to mount the red cube? Photos would be invaluable.
