I had to run ground wires because the connection to my EFIS (actually the engine pod) was sensitive and didn't work through aircraft ground. That meant I had to isolate the mounting plate with plastic shoulder washers and use a ground wire back to the pod. It's fortunately a fairly easy retro-fit, though, so feel free to try the airframe ground first and see if it works for you.
