Thanks for all the suggestions. I also called Lockwood Aviation. I did find that the fuel was coming from the vent tube and Kerry at Lockwood suggested that it was probably some trash under the needle and that I should remove the bowl and floats, run some fuel through the carb while jiggling the valve. I did this and did not find any trash but the problem stopped. Thanks again.
