Steve Emmett
Member
I am at the point where I need to start thinking about an engine. I am interested in hearing peoples thoughts about the pros and cons of fuel injection. Thanks
I'm one of the lean carb guys.....dan said:Carbs sure are simple, right?
Except how many people have you seen posting on various lists where they end up having to re-jet their carbs, chasing down too-lean or too-rich this and that? I hear about some folks having to go with a completely different model carb to solve the problem. Wha?! Isn't an O-360 is an O-360 is an O-360?! Seems like an epidemic lately. Maybe it's just what I've been reading.
Take a look here.Don Vosgien said:Great,
Fuel Injecton sounds great. Where can I get one for the O-235 I want to put in my 9A? Just joking, I know I will be stuck with a carb. But, one can dream of having a fuelie O-235 engine!![]()
Don Vosgien
Don Vosgien
Yes, but do you have it for an O-290?Don at Airflow said:Don't dream. A 235 mechanical fuel injection system is already a reality! We have Kit #8000004 for that application.
Also you can put FI on a up draft sump but have ram air too. We have a kit that uses a elbow to face the fuel control forward and a alternate air duct that allows unfiltered ram air or filtered alternate air.
Lots of options.
Don
N941WR said:Yes, but do you have it for an O-290?
Is this a throttle body set up or do you put the injectors on each cylinder?
I cruise around at 6.5 to 7.5 gph at 160 to 170 KTAS, depending on altitude. With O2 + FI + EI @ LOP, high altitude economy is ridiculous. I spent $$$ to have that full system, but I wouldn't have it any other way!Noel Simmons said:...TAS of 152KTS it really could get somewhere burning only 8.5 GPH.
