for those!
I see you have the fwd facing sump offered by Barrett. Did you have to do anything different with cowl/exhaust/motor mount to install that setup? Let us know the details of that install if you can.
That looks like the Airflow Performance FM300, right?
What did you do for ignitions?
Will James makes an RV-10 cowl that is specifically built for the BPE cold air sump. I installed it and his fathers plenum.
http://deemsrv10.com/album/Sec FF2 Baffling and Plenum/index.html
At the time there was no provision for a filtered/alternate air system that fit the Oval induction ring on Will's cowl. (Will may be working on a solution by now) so I modified the cowl to accept a 3" circular induction and utilized Rod Bowers RAM/Filtered/Alternate air system. The installation of the plenum also required some modifications that you should see in the pictures.
The Exhaust is built by John Forsling, and is ceramic coated inside and outside. He had worked with Allan & Monty @ BPE and has tried out different configurations of tuned exhaust on the BPE dyno, to determine which yields the best power output. The one I have was specifically built and tested for the cold air IO-540.
There is a slight modification to the engine mount that requires a crossmember to be cut and replaced with one which is bent to allow for clearance of the sump. BPE has arranged w/ Van's to have the motormounts dropped shipped directly to them and they do the modification as a part of their engine build. (several pictures here)
http://deemsrv10.com/album/Sec FF1 Engine Installation/slides/DSC04011.html
The fuel servo is an FM300, it's a gas guzzler if flown wide open but it also allows for increased HP if I want or need it.
I'm using Mags at the present time, When I spoke w/ BPE they maintain that when they run engines w/ EI on their dyno, they see a decrease in HP, and that wasn't an interest to me. This topic is highly debated, in the end I chose to go w/ mags and wait for more evidence and development of EI for 6 cly engines.
There are detailed write-up of the step by step installation of each of the components that can be found in the Construction Log
http://deemsrv10.com/constructionlog.html
Click on the respective section of Van's plans in the log, that will open up another page where entries are organized by plan page/step, or if it's a mod they are organized chronologically. then click on the specific step/range of steps to see the details.
Hope this helps
