Steve Sampson
The standard straight ended fuel hose that VANS advise , coming off the fuel pump, does not work for me. Have others had this problem? It bumps into the engine mount , hard, before it can turn away. I have put some pictures here. http://gikonfwf.blogspot.com/2007/09/fuel-hose-problem.html#links (If the pictures are not clear when you get there just double click them.)
I think I will have to get a hose made up with a 45deg swivel fitting on the end but would really welcome ideas before I go ahead.
