I have the Dynon D180. I currently have things hooked up to the Vans gauges, which I feel are incredably accurate. Dispite what others might think. Mine are accurate from 15gals on down. Now I would like to put my Dynon system into use. I have the variable pickup in the tanks from vans. I wish I would have known about the issues of parrallel of the vans gauges and the Dynon when I built the tanks. I would have put capacitive sensors for the Dynon in the tanks. Oh well, I can't go back on it now. So, I have this problem of what to do.
Should I:
Put a switch in and have it toggle between the Dynon and vans gauges when I want to check supply against each other.
Or, is there a capacitive sensors I can install in the tank from outside with the wing root covers removed that I can purchase and install for the Dynon.
Right now I'm trying to get a handle on the fuel flow, not sure if it is right. On take off I have about 12gal an hour rate and at 23square I'm burning about 9.2gal an hour, lot of times I'm running 23rpm-25 at about 10.5, seems high, I usually put in 8gal an hour at fill up. I have the xp360 fuel injection, plasmaIII, cc prop hartzell. I have all wheel pants except wheel covers on the mains.
Should I:
