B
bmiller269
I've been trying to figure out a fuel gauge issue can someone that may have had this issue give me some help? The issue is that all of a sudden BOTH gauges read full when you turn the panel on. In flight sometimes one or the other gauge will slowly show a proper reading, but then go back to full pin pegged. I thought it was a ground issue but have ran a test wire to the ground terminal with no change. Someone told me it was the sending unit but both at the same time. Seems Unlikely. Any Help Thanks
