Most all posts deal with Low Fuel Pressure. My problem at various times Fuel Flow will go crazy high , indications on last flight were anywhere between normal …..
to 25 to 60 to over 100 at one point. I thought it might have fixed itself after about 15 minutes. However after entering pattern the indications came back high , even at the lower power settings. Taxi it was still reading high …25 to 40. My normal pressure cruising if I don’t lean is @ 11 gph. Fuel Pressure normal.
Engine running normal…. No obvious signs of fuel leak or smell
O-360, carb, Dynon Touch monitor.
