Chadmeyer24
Active Member
I know this has been talked about many times but I'm having an issue with one of my fuel caps. The seals are good and I have tried tightening the nut and loosing it. Every combination seems to not work. What is happening is the cap will rotate loosely in the hole and in flight will actually raise up around 1/8in acting like it wants to pop out.
What are my options?
Thinking about just ordering a new cap from vans as they are only $28.
My other question is is there any better fuel caps out there with a better design? I'm just not found of the Vans caps... and off course I'm talking caps that will retrofit without redoing the filler neck!
