rleffler
In testing my first fuel tank, it appears that I have a leak. The only leak I can find in the fuel cap. Air bubbles were coming up from under the tab. I moved the tab to different positions to ensure that the leak moved with the tab and to rule out the leak was coming between the flange and skin. The leak did move. So I decided to increase the tension by ?? turn. That helped eliminating the leak around the seal, but it does appear that I still have a leak coming from the center post. It also appears to be the same with both fuel caps.
I?ll give Van?s a call in the morning, but I was curious as if anyone else has run into anything similar and have some advice to share.
Bob
Bob
