The power wires from the fuel and oil pressure sensors can be combined on the same pin on the Dynon EMS. The same is true for the ground wires. Instead of running four wires to the EMS, why can't I just splice the power wires together and the ground wires together at the sensor, then run one red and one black wire to the EMS?
If this is acceptable practice, what is the recognized method to splice the wires at the pressure sensors? Solder crimps? Just use butt splices with shrink tube over it?
![Fuel and Oil Press Sensors.jpg Fuel and Oil Press Sensors.jpg](https://vansairforce.net/data/attachments/22/22707-ec5fea0095ad2af2b6a8d23c1b0fc4d2.jpg)
