Anyone run teflon fuel lines from the tanks to the valve, and would know the lengths needed. I attached the Andair valve to the tunnel cover, and now considering running a one piece line to the tank.
Second question. Anyone see an issue placing the ANL fues before the amp shunt. Running two aternators (one is a back up) and want to run the B leads from each one to the shunt. This will require the ANL fuses before the shunt. The wiring diagrams I have seen places the shunt before the ANL fuse, then to the hot side of the starter solenoid.
