SOLD: Amazing RV-14A
MS19087
AIRCRAFT HAS BEEN SOLD AND DELIVERED TO LUCKY NEW OWNER - I am parting with my RV-14A to build an RV-10. It is an excellent build and wonderful performer. No expense was spared on this build, see modifications listed below. I am a two time builder and can provide references to any interested party. All documents available and lots of pictures available to interested parties.
BE SURE TO CHECK OUT POST 2 FOR ADDED PHOTOS
RV Model: RV-14a
Quick Build (QB) or Standard Build (SB): QB (DELIVERED PRIOR TO CORROSION OR LCP ISSUES)
Slider or Tip Up: T/U
S/N: 14561
Asking Price: $330K OBO
IFR/VFR: IFR
Why selling: BUILDING RV-10 (2 TIME BUILDER)
Total Time (hrs) on airframe: 120
First flight date: 3/20/2022
Original Builder (y/n)?: YES
Empty Weight (lbs): 1283
- CG (empty weight - inches from datum): 81.63
- date of last weighing:
3/23 AFTER PAINT
Year painted: 2023
- Painted by: LANCASTER AERO
Engine Make/Model:
LYCOMING THUNDERBOLT IO—390 EXP119 W/ ACCESSORY CASE
- HP: 215
- Total Time Since New (hrs): 120
- Time Since Overhauled (hrs): 120
- Ignition: DUAL P-MAG
- Carb/FI: FI. FM-200
- Exhaust system: VETTERMAN
- Engine Purchased from: LYCOMING
- Date of last compression check: 3/2024
- - Cylinder #1: 79/80
- - Cylinder #2: 79/80
- - Cylinder #3: 79/80
- - Cylinder #4: 79/80
Other unique features FWF: MONKWORX BACK-UP ALTERNATOR; B&C ALTERNATOR; B&C STARTER
Prop:
HARTZELL EXPLORER 74” 3 BLADE COMPOSITE W/ ALUMINUM SPINNER
- Make (FP or C/S): C/S
- Model: EXPLORER
Flaps (manual / electric):
ELEC
Rudder Trim (manual / electric): ELEC
Elevator Trim (manual / electric): ELEC
Aileron Trim (manual / electric): ELEC
Strobes Make/Model: WHELEN CERTIFIED LED
Landing Lights Make/Model: FLY LED
Age of tires/tubes: 1 YEAR. BERINGER WHEELS, BRAKES AND CYLINDERS AND BERINGER TPMS
Avionics: FULL GARMIN PANEL (Avionics Systems build)
G3X x2
-GNX375 Certified navigator w/ ADS-B transponder
- GNC255 Nav/Com
- GMA 245B Audio Panel
- GTR200 Remote radio
- AUTO PILOT W/ YAW DAMPER
- G5
- BACK UP ALTERNATOR
- GMC507 A/P controller
- GDL-51R SXM
Interior:
LEMKE LEATHER
Modifications:
- CeiS fuel senders
- JD Air canopy latch
- Aluminum fuel caps
- Aircraft Specialties braided brake lines, insulated fuel and oil lines
- B&C Alternator
- B&C Starter
- EarthX 900 battery
- Forward fuselage access panels
- Aircraft Specialties Glare Shield
- Control Approach Rudder Pedals
- Monkworx 30A back-up alternator
- Garmin YAW damper
- Center console
- Bruce’s deluxe Canopy covered
- Kroger shade
- 4D oxygen bottle & Carbon fiber mount
Real World Cruise Figures:
- 160__kts IAS at __22__" of MAP spinning _2400_rpm while burning ___8.6___ gph. ALT 4500'
- 170__kts IAS at __24__" of MAP spinning _2400_rpm while burning ___9.6___ gph. ALT 4500'
Past incidents/repairs/damage repair:
NO ACCIDENT HISTORY
- ALWAYS HANGARED
Service bulletins/Change notices that have been complied with:
ALL COMPLIED
Date last annual: 4/2024
- Maintained by: OWNER/BUILDER
Date last transponder check: DUE
Date aircraft last flown: 6/4/2024
Willing to deliver: YES
Added a few more updated photos. Note the attention to detail. Screwless/hinge secured wingtips, blended fiberglass tips, perfect spinner fit/alignment, clean empennage fairing attachment.
Hope this goes to a deserving hangar! Get off the fence and contact the seller if you even have the slightest interest. I’ve seen it being built and have been lucky enough to have flown in it a few times. If you value high quality workmanship and finish and want a beautiful inside and out 14A that is very comfortable to be in and is ‘smooth’ this is the one. The noticeable smoothness and noise(less?) frequency sense is likely due to the balanced 3 blade prop coupled to the Thunderbolt engine along with the yaw dampener probably being the main differentiator to the 2 blade non thunderbolt RVs I’ve owned or flown in. Someone is going to get a winner.
This is a stunning aircraft. Mark is a meticulous and detailed builder. He's also a great guy and someone is going to get one of the nicest 14s out there.
