Bill Phillips
The front stick was pre-bent when I purchased the kit year's ago. I mounted a Tosten grip on it. They are approx 165 mm long. I tried to cut that much off the steel stick tube, but ran into the top bend action in the stick so I'm about a half inch too long. As a result, the top on the stick will not push under the panel. Does it have to? Thanks, Bill
