Hi there,
I am working on page 8-3 on my RV-10 project. Unfortunately I misread the instructions and ended up cutting the AA6-1872X2-1/2 to the incorrect measurements. The length of the where there are two holes drilled or "bottom" calls for a 1inch by 1 21/32nd. For both right and left brackets I ended up cutting the length to 2 21/32. If I cut the piece to the correct length of 1in the width is 1 17/32 for the Right bracket and 1 18/32 for the left bracket. This is to make parts HS-1008R/L.
Is this a redo?
Hopefully I have explained the problem fully and is understandable. Any help would be greatly appreciated.
-Marcos
Is this a redo?
-Marcos
