I'm riveting the forward fuselage side skin (F-1069) to the longeron (F-1013). How do you get the very front rivet under the F-1001J firewall gusset? Anything thin enough to fit in is simply not going to have the weight to set the rivet. ![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I was considering removing a bit more metal in the skin dimple, opening the hole to 1/8 and using a cherry-max.
Any suggestions?
Any suggestions?
