Busy installing the front NACA vents. Curious to know what you did with them to fit in with the Aerosport panel air outlets. Don't have my panel yet so I am not sure about gap and alignment between vent and panel outlet.
Did you cut the square flange off the plastic vents prior to installation?
Did you use NACA vents with the 2" outlet as for the rear vents instead of the supplied front vents with flange attached?
I assume you have to install one of these vents (or similar) into the panel: http://www.steinair.com/storedetail.cfm?productid=313
(Don't know how to make hyperlink within VAF website)
I don't want to permanently install them with the flanges on and then later realize I have to cut the flanges off.
Thanks.
Johan
Thanks.
Johan
