Front Mount Gov Advice
6 Gun
My engine that Im installing in my RV6 has front mount gov pad and need advice on cable bracket set up from others that have same set up on Lycoming.Pictures are great for the vis.
Thanks Bob
here's how I did it...
The throw on my governor was reversible but had to be done by the factory... changing the clocking is no problem in the field though. I modified a 'standard' Vans bracket and used a -10 length control cable.
