Has anyone tried installing fresh air vents into the round inspection plates adjacent to the rudder pedals? It seems like a good way to get air down by your feet without cutting into the fuselage skin. You could even remove them in the winter and repalce with the original solid plates if you had air leakage. There is probably a way to make them operable in flight with a cable. Any other ideas on getting more fresh air into an RV-3?
