Hi guys/gals.
Anyone here have an exploded view of the original Vans the tails heel assembly?
I've lost the ability to steer properly, locking pin seems to have failed and I am unaware of what the original set up is meant to be, not the builder.
Cheers.
Thanks guys.
I disassembled the original tail wheel and found after cleaning that the locking pin was jammed in the retracted position due lack of lubricant. Seems the grease nipple does nothing?
After cleaning, lubrucation the original set up works well.
I had considered an after market assembly but the cost is prohibitive due a poor exchange rate I now have full authority back
Thanks guys
I only had engine oil at hand when I reassembled the set up but shall get some dry lube.
I can't see what the grease nipple does? There was no sign of grease inside at all and it has been greased a few times?! Odd?
