I am trying to program my FPS -Plus-reflex on my RV10 without success. I am only setting the flap position and not doing anything with the trim. It all appears to be wired correctly and operates up and down in Mode 1. The POS-12 sensor voltage changes across pins 8 and 3 as it is supposed to. I changed the blue and orange wires to get the correct movement of low voltage flap down/high voltage flap up.
I can access mode 5 OK and erase previous settings. I start by moving the flap to up. I select my first setting and get the green light when pressing the set button. Same with second setting. If I then go to Mode 3, down selection does nothing and up moves to fully up and then it will not move down. If I take the flap to fully down before going to Mode 3, I cannot move it up.
I feel I am missing a step somewhere even though I seem to be following the instructions. Any ideas?
